narayani
Full Member level 2
I am getting error during annotation of DC Voltage and current using AWR MWO. I am not able to find out how to get rid of this error. Actually I wanted to check biasing condition for Power Amplifier.
Even I am not able to plot IV Curve plot that is also showing error. I have attached AWR MWO IV Curve plot file.I believe that is a compatibility problem. Or it's a particular isue.
From the developer's design, it is unclear how many transistors of the BLF647P assembly should be used in the circuit. If it is one, then the lower transistor should be excluded from the DC calculation by shorting all its terminals. Otherwise, the upper and lower transistors will short-circuit L2 and DCVS ID_V2 V= 32V. If the transistors are intended to operate in parallel, then the circuit needs to be configured in the second way.Shorting all the pins of the MOSFET at the bottom, I don't think it's a solution..
Hi Narayani! Post a screenshot of the diagram.
May I know which version of AWR MWO are you using?I am using latest 18 version and didn't get DC annotation. I have 18 version AWR MWO under university license program.Hi Narayani! This is what I got after simulation
I have 17.02 version AWR MWO.May I know which version of AWR MWO are you using?I am using latest 18 version and didn't get DC annotation. I have 18 version AWR MWO under university license program.
