Get rid of high freq noise(not very high) without using filter
simbaliya
Member level 4
Member level 4
Is there a way to remove the high freq noise using method other than filter, because my BW requirment is larger than the noise frequency.
Hey gentle man
Hi
you have many simple way: first way: use notch filter with narrow Q factor. second way : feed back in frequency of noise. or ..... etc!
Best Regards
Goldsmith
You'll have to be more specific about your noise and signal characteristics.
Anything that removes noise from a signal is pretty much a filter by definition. So either you'll need one, or you'll have to prevent the "noise" from coupling to the signal in the first place.
