ysba
Is there some way of get rid of audible noise in a quasi resonant flyback supply?
The noise appears at very low load conditions. It is not a high pitch sound, it's more like a sizzling sound. The controller is LM5023 which has a pulse skip feature. I looked at MOSFET's drain voltage signal. In fact, the controller makes a burst of pulses and then turns off for a while. I think this turn on and off condition is making the sound.
Could be a poor designed loop response capable of doing this?
What more could I look in order to keep the supply quiet over the entire load range?
Thank you,
Yuri
Thank you,
Yuri
