get power from 4-20mA signal line
cdcll
Full Member level 3
Full Member level 3
I need help for how to get 24V/2mA from 4-20mA signal line, any recommendations and experiences are welcome.
You probably wouldnot get a full 24v, but I have seen circuits getting about 8 volts from this line. It also depends how much the loop of 4-20ma is powered up with.
hello
AD company have several AN on this,you can see the data sheet of AD*693 for lo0p p0wered m/a lo0p.
NS also have several AN on this subject.
bye
4 mA max
The current drawn must be lower than 4 mA unless the data you are sending over the line will never be a value represented by low currents.
Found somewhere on the net
Schematic foud somewhere on the net ...
