Gerber to OrCAD file or a footprint - conversion possible?
cosmicboy
Junior Member level 2
how to convert a gerber file into max file
Hi folks,
I am trying to design an add-on pcb that will sit on top of a development board but because they are using some very obscure margins between connectors I am having quite a few problems matching them.
I do however have the gerber files for the development board so I was wondering if there is any chance I can import that gerber file (just the connectors part actually) into OrCAD Layout either in to my .max file or even in to the Library Manager as a custom footprint..
Any ideas?
Thanks!
gerber to orcad
Export gerbers to DXF then import into layout. This gives you template to work with.
Regards,
M
    cosmicboy
orcad gerber
With some help I managed to do exactly that, thanks for the suggestion majnoon :)
