Goldenshuttle
Member level 3
- Joined
- Sep 30, 2011
- Messages
- 58
- Helped
- 0
- Reputation
- 0
- Reaction score
- 0
- Trophy points
- 1,286
- Location
- North York
- Activity points
- 1,801
How much time do I need to design a PCB for this circuit ?
Thanks for commenting. I need to make a neat PCB for a talking mouth servo. I always used strip board but this one I want to make a proper PCB, maybe order 5 pcs online as they quoted me 2.5$/pc but they wanted a gerber file.... No experience on gerber PCB design, or what software to use..usually using my head to work around strip board. is there a free software to do it or i need to buy a license.?How long depends on how long you've done something like this before.
Why are you choosing this design?
Thanks BetWixt. im using normal componenets not sufrace mount. LEDs 5mm sitting in the PCB. the pots are small presets like these below...no exact constraints I was thinking 2x2 inch maybe enough.An impossible question to answer without more details.
Are the components through hole or surface mount?
What size constraints do you have (board dimensions)?
There are three potentiometers, are they board mounted and if so, do they have to be in fixed locations to match the enclosure?
There are three LEDs, do they need to be in a fixed location to match the enclosure?
If you want a "ball park" answer, I would estimate 2 - 3 hours using Kicad if all the above were known.
Brian.
