Geometry error in Momentum ADS
Vijay Vinay
Member level 5
Member level 5
Hello all,
I have drawn the layout for my inductor design. When I try to run ADS Momentum, it returns with a error message "The following exception was raised during geometry processing: basic_ios::clear" and doesn't perform the S-parameter calculations( in my case). I am not sure why there is such an error being displayed every time I change the layout design and try out Momentum simulation. An immediate reply in return would be helpful. Thanks in advance.
Attached you would see the layout design of my inductor
Are you using ADS Momentum under Cadence ADE ??
Hi guys,
Is there any way to solve this issue. If there is any, could you please post the solution at the earliest. Thanks in advance.
