Anoop
Newbie level 1
Hello,
I'm trying to generate a continuous PWM wave on a scope from the C8051F330 micro-controller using external interrupts and timers only. I have put up a piece of code. Could anybody please look at it and spot any mistake/mistakes that I've been doing which is eventually restricting the output...? The code is as follows:
Many Thanks.
// Include Files
#include <compiler_defs.h> // Macro definitions for 8051 Compiler //
#include <C8051F336_defs.h> // SFR declarations //
// Global Constants
#define SYSCLK 24500000/12 // Clock speed in Hz //
SBIT (SW1, SFR_P0, 7); // SW1==0 means switch depressed
// Function Prototypes
void Oscillator_Init (void); // Configure the system clock //
void Port_Init (void); // Configure the Crossbar and GPIO //
void Timer2_Init (int counts); // Configure Timer2 //
void PCA_Init (void); // Configure PCA for PWM mode //
void Ext_Interrupt_Init (void); // Configure External Interrupts (INT0) //
INTERRUPT_PROTO (INT0_ISR, INTERRUPT_INT0);
// MAIN Routine
void main (void)
PCA0MD &= ~0x40; // Disable Watchdog timer //
int RELOAD_VALUE = 0;
Oscillator_Init(); // Initialize the system clock //
Port_Init (); // Initialize crossbar and GPIO //
Timer2_Init(SYSCLK/100); // Initialize Timer2 to generate interrupts at a 20kHz rate//
PCA_Init (); // Initialize PCA for PWM //
Ext_Interrupt_Init(); // Initialize External Interrupts //
EA = 1;
while(1) // Infinite while loop waiting for an interrupt //
if(TF2H == 1)
if (RELOAD_VALUE<65535)
TF2H = 0;
PCA0CP0 = RELOAD_VALUE;
RELOAD_VALUE ++;
else
TF2H = 0;
RELOAD_VALUE =0;
// Oscillator_Init
// This routine initializes the system clock to use the precision internal
// oscillator as its clock source.
CLKSEL = 0x00; // Clock Select. SYSCLK is derived from the Internal High Frequency Oscillator and scaled per IFCN bits in register OSCICN //
OSCICN = 0x83; // Internal H-F Oscillator enabled and SYSCLK derived from Internal H-F Oscillator divided by 1 //
// Port_Init
XBR1 = 0x40; // Enable crossbar and weak pull ups //
P0SKIP = 0x7F; // Skip unused pins on P0 and P1 //
P1SKIP = 0xFF;
// Timer2_Init
TMR2CN = 0x00; // Stop Timer2. Clear T2SPLIT.
// Use SYSCLK/12 as timebase, 16-bit auto-reload
CKCON |= 0x30; // Timer2 High and Low byte uses the SYSCLK //
TMR2RL = -counts; // Initialize reload value
TMR2 = 0xFFFF; // Set to reload immediately
// PCA_Init
void PCA_Init(void)
PCA0MD = 0x00; // PCA Counter/Timer Idle Control enabled, Watchdog timer disabled, Watchdog timer enable unlocked, Unused, System clock divided by 12, Disable CF Interrupt //
PCA0CPM0 = 0x82; // PWM 16, ECOM, TOG, PWM, ECCF bits set //
PCA0PWM &= ~0x80;
// Ext_Interrupt_Init
TCON = 0x01; // INT 0 is edge triggered //
IT01CF = 0x07; // INT0 active low; INT0 on P0.7 //
EX0 = 1; // Enable INT0 interrupts //
// Interrupt Service Routines
INTERRUPT(INT0_ISR, INTERRUPT_INT0)
TR2 = 1; // Start Timer2 //
Many Thanks.
