Hi to all
I have an acoustic project an I shoud generate a noise-like signal in MTLAB based on ASTM E1050 standard.
the noise specification is :"It is recommended that the test signal
consist of broadband random noise; however, other test
signals such as pseudo random noise or sine-sweep excitation
could also be used."
please introduce me an efficient way to produce either of signals above.
Here is a question: What will be used to have a white noise: rand(uniform distribution) or randn(normal distribution) functions of matlab. And here is a comment on the subject: a stream of uncorrelated random numbers constitutes white noise. Then what is your comment?
thanx
rand is good for my job. but here is another question: when i plot frequency spectrum of this noise, the plotted spectrum is not flat anough and I think that broadband random noise should have flat spectrum ( i don't if this is true?).
what is your opinion for its spectrum.
I think that using an equalizer would solve my problem. if yes help me to design it.
Uniform white noise and gaussian white noise both give you flat spectrum. They have different point distributions.
s = rand(10000,1) - 0.5;
plot(abs(fft(s)))
s = wgn(10000,1,1); % maybe requires communication toolbox
plot(abs(fft(s)))
mro83, do you see something non-flat there? Maybe you simply need to increase the number of data points to see the flatness. The spectrum is noisy of course, but it's flat.
