Generating PWM with PIC32MX460F512L
ssquared
Junior Member level 3
I am working on a project to generate PWM signal with PIC32MX460F512L to drive a motor. I have written the code to drive a motor with a signal of frequency 10KHz. I have tried to test my code but it is not work. I would appreciate of someone can advice me one how to proceed.
#include <plib.h>
#include <stdio.h>
#include <stdint.h>
#include "Cerebot.h"
#include "Lcd.h"
#include "config.h"
void initTimer();
void initOC();
int main(void)
	Init_Cerebot32MX();
	initTimer();
	initOC();
	_CP0_SET_COUNT(0);			// Delay 4 Seconds
	while(_CP0_GET_COUNT()< 4*40000000)
	OC1RS = 500;				// Set Duty Cycle to 50%
	TRISG = 0x0000;				// Set PORTG as output
	while(1)
		PORTGbits.RG12 = 0;			// Set pin RG12 as output
} //end main
void initTimer()
	T2CONbits.TCKPS = 1; 		// Timer 2 Prescaler of 1:8
	PR2 = 999;					// Period = (PR2+1)*N*12.5ns = 100us
	TMR2 = 0;					// Initial TMR2 count is 0
	T2CONbits.ON = 1;			// Turn on Timer 2
void initOC()
	OC1CONbits.OCM = 0b110;		// PWM Mode without fault pin
	OC1RS = 250;				// Duty Cycle = OC1RS/(PR2+1) = 25%
	OC1R = 250;					// Initialize before turning OC1 on
	OC1CONbits.ON = 1; 			// Turn on OC1
This is no useful information.
--> give a detailed error description.
What did you already do to debug the code?
What were the results?
Comment out all code that you don't want to test, focus on what you want to test.
Klaus
I think you are trying to generate a PWM so I would suggest you to break your code in pieces. First of all, simply generate a regular pulse and then try to change its frequency by fine tuning. PIC Microcontrollers have builtting pins but you have to enable the registers as well in order to use them for PWM purposes.
Thanks.
