basically there are two ways to generate negatives volatges from a positive source . A switching power supply with transformer or coil ..
depending on your power requirements .. it can be as easy as a transistor and a coil. The second possibility is a "CHARGE PUMP " is basically an analog switch commuting the poles of a capacitor .. poe A is connected to positive source .. pole B is grounded .. is charged in time T depending of the cap capacity . Next cycle capacitor is completly disconnected from source and pole A is grounded pole B is connected to LOAD .. The best configuration is to have two caps while one gets charged by the source the other powers the load.
You mean negative voltage from positive source or you mean to generate negative voltage from AC source? If you want to generate neg. volt. from positive try to use SMPS to produce from positive.There are many chips and designs for it.Simply google it.
If you want to produce from AC, it is very easy to produce it.There are many instant chips like LM79XX.Just regulate it with bridge diode and apply to 79XX you'll get negative voltage.
