virus
Member level 1
How could I generate higher voltage with a PWM signal?
I had tried the following:
With PWM signal (93,750 kHz, 50% duty cycle, 5V) input to VPP_PUMP. If the VPP_FEEDBACK is lower, the PIC will increase the duty cycle, until the final output voltage reaches 13V. But when I turned on transistor Q3, additional load causes the output voltage to drop to about 10V. I seem not able to get the intended output 13V no matter how I try, for example experiment with different PWM frequency, various duty cycle limits.
Could anyone point me my mistake?
Thanks.
Thanks.
