patan.gova
Full Member level 3
Hello,
I want to generate a signal similar to the one shown in the attachments acquired using labview which is the output of a phototransistor.The output image contains 10 signals each contaning each acquired by using 1k samples and below freq images shows freq components only 1 signal of 1k sample.
The images2,3 represent the freq component present in a single sample.From the images it can be analysed that it has DC volatge of 2.6V but I am confused as it contains different frequenices and most(very high number) of the frequencies are lying below around 1Hz and some are lying at around 135 and others at 275 to 300 and very less number of other frequency components.
What all things to be taken to generate these kind of freq's in multisim/LTspice and How to add these different kind of frequencies to the DC component so as to generate the signal that will be same as in the shown image.
I want to genearte this signal in multisim/LTspice as this will used as a input for designing the filtering stage in multisim/Ltspice.
Thanks.
Attachments:View attachment Generate_signal.pdf
Thanks.
