[SOLVED] GDSII file required urgently (simple inverter fm transistor))
Vivek1
Junior Member level 2
Hi all,
Please help me to provide GDSII file of simple inverter that will contain at least one transistor.
Thanks in advance.
If you operate a single transistor in common emitter mode, you get inverted polarity of the incoming signal, by taking output from the collector leg.
Sorry, I didn't get your point.
Tell us what progress you have made so far in regard to your question. Then you may get replies in regard to the point you're looking for.
Still I'm not able to get any file.
And I'm looking for a transistor file that have designed using any software like CADENCE or ADS in GDSII format with their respective thickness. So, that I can work on that file as 3D model.
you will not get this type of thing here. you need to work with someone that understands the process to give you the thickness info. it does not come with gds files
Thanks all.
timof I have already gone through that one but not any use for me, as you already described in your comments.
Why is it so difficult to build one for yourself rather than asking around and waiting?
It is just a simple inverter after all...
Assumption: You have access to the relevant tools!
Thanks dpaul, but I don't have access of the designer tools. And I have solved this problem.
