Gaussain Noise in Matlab 1/sqrt(2) (randn(no of bits)+j.*(no of bits))
aliazmat306
could somebody please brief me the following method of generating Gaussian Noise specially the term sqrt(2), i.e., why it has been used here
Thank you very much for your time!
Hi
It is just to keep variance of each sample to be one. randn() function in MATLAB results in a Gaussian noise with zero mean and unit variance. So, variance of randn() + j randn() would be 2 and to keep its variance to be 1 a scaling factor of 1/sqrt(2) is multiplied.
Hope this helps
but simple algebra shows that
1/sqrt(2)[1+1] = 1/sqrt(2)
I mean the variance of sum of two independent normal Gaussian Random variable is 2. (Agree)
but when scalar factor (1/sqrt(2)) is multiplied the results is 1/sqrt(2) not 1.
plz explain, I am confused.
Hi
Kindly note that \[var(aX) = a^2 var(X) \]. So, multiplying by \[\frac{1}{\sqrt{2}}\] scales variance by \[\frac{1}{2}\]. Thus total variance is (1+1)/2=1.
Thank you very much dear MHanif. This answer is what I wanted.
Thanks Again!!!
