Arnab1233
Newbie
Currently, I am engaged in the design of a Thermal Shutdown circuit for an LDO regulator. In this endeavor, I have obtained a circuit schematic from a senior colleague, which utilizes three NMOS transistors configured as voltage dividers.
This particular arrangement is employed due to the minimal current flow observed across the branch, which is on the order of picoamperes.
I have provided an attached image of the schematic for reference. Subsequently, I conducted simulations and confirmed the circuit's satisfactory performance.
However, I am now seeking a mathematical approach to determine the aspect ratio of the transistors and the resulting resistance offered by the MOSFETs, as they operate in cut-off mode.
Unfortunately, I have been unable to locate a suitable formula that elucidates the resistance of a MOSFET in cut-off or subthreshold conditions, including the role of non-zero body-source voltage of the upper two MOSFETs.
