aguntukbd
Junior Member level 2
I am designing integrated DC-DC converter with multiple output. As I am new to Analog design, I am trying to figure out what type of circuit topology is to be used for high-side and low-side switches. High-side is a pmos and lowside is a nmos switch. I am using 22nm technology with typical Li-ion battery input voltage (2.5V to 4.1V range, nominal 3.7V).
I am using 22nm technology. Though for the high-side and low-side I will try with LDMOS. I am just not sure which topology to use from the PWM output to the LDMOS for driving the gate. What I mean, I am looking for gate driver circuit. Googling give me mostly to use gate driver ic to use which is not my intention. I want to start with common gate driver topology to start with. I figured my peak current required and switching frequency as well. I also sized preliminarily my LDMOS with current requirement. I need to drive the mosfet now from digital PWM. So I have to drive the MOSFET to design a circuit between the DPWM and the pmos /nmos as well and as well as nmos and other switches. Now for PMOS I selected the lowest voltage of Li-ion battery 2.5V and input pwm voltage would be 1.8V during its ON-duty cycle. Can anyone suggest what type of circuit should I use to drive the gates of the switches, specially pmos?
