cupoftea
Advanced Member level 5
Just bringing up a 24VIN, 24VOUT, 48Wout, 60kHz flyback.
Controller has only 5V gate drive, and weak, so used a UCC27517 gate drive IC from this
PWM controller to the NFET.
The UCC27517 gate drive IC was, I believe, ESD killed. I replaced it and now the flyback works, but the controller's
current sense pin is blown...(no doubt from the high current from when the FET was held perma-ON putting a too-high voltage across the source
sense resistors.)
Anyway, we have now got a Schottky connected from UCC27517 output to rail, and also another Schottky connected from UCC27517
output to ground (anode to ground, cathode to rail)
Do you believe this is a necessary precaution for this sensitive gate drive chip?
Gate drive ICs, often seem to get blown or ESD damaged, sensitive things they seem to be.
UCC27517
UCC27517
sense resistors.)
UCC27517
UCC27517
