Gate-charge simulation in hspice
cmos80
Newbie level 5
Newbie level 5
Could someone please help me with the gate-charge simulation netlist?
Trying to use 2 fixed current source ig & id but I encountered 2 problems:
1) vd vs charge, vd rises initally before decreases as expected
2) vg does not level at maxVg=6V
Thank you in advance!
******* QG Simulation ***********
.OPTION post nomod ingold=2
.param ig=50p maxVg=6
.param id=1m maxVd=30
mn1 d g s b nmos1 w=10u l=1.5u m=100
iscr1 0 g1 pwl 0 0 0.001 ig
iscr2 vdd d id
vda vdd 0 maxVd
vga g g1 maxVg
vss s 0 0
vbb b 0 0
.ic V(d)=maxVd V(g)=0
.tran 0.01 1
.print vd=par('v(d)') vg=par('v(g)') id=par('id') ig=par('ig')
.model nmos1 nmos level=49
.end
You're not going to get a meaningful gate charge result,
when you have no parameters at all on the MOSFET model
(particularly cgb, cgd and cgs related ones).
In this simulation, the key is the gate capacitance which is defined by the tox and tox has a default value. So, i don't think this is the reason for the simulation not running correctly.
Is there any kind soul can debug my netlist? thank you!
basically, i want the voltage to stop climbing when it reached maximum vg value to match my measurement data.
any method to achieve this?
Pls help!! thanks!
