lixnig
Newbie level 5
What is the proper way to connect a GDT in a circuit to protect against large surges in a system? Is it simply from supply rail to ground so as to shunt the surge away from the equipment?
Secondly, hooking up a GDT across an AC source with a magnitude high enough to cause the GDT to conduct would cause the device to see a very shortened life. Is that correct?
Chris
Chris
