x_ngine
Junior Member level 3
Hi, I want to build a circuit to control my garage door opener over WiFi.
I figured the WiFi part but I have problems with the circuit-to-opener communications:
1) Most circuit I have seen online directly connect the circuit to the opener via wires. Unfortunately my model of opener is pretty new (liftmaster 8355, with security+ 2.0) so it seems I cannot just short two of the header inputs to force the opening. It seems there is some non-trivial communication going on over those wires (from the wall controller to the opener on the ceiling). Does anyone has some information about this?
2) Alternatively if option (1) is not doable I was thinking to embed the same radio controller used in remotes into it so that the circuit, once paired, can actually sit anywhere in the garage instead of hanging from the opener, a cleaner setup. I have been looking on the internet but haven't find any source of inspiration or indication of which IC to use: I'm assuming there must be a single IC doing the whole thing (security+ 2.0 rolling). Any idea?
