E-Floyd
Newbie level 3
Hello everyone,
I have a high voltage measurement sensor which has one high voltage measurement input (+450V & Gnd reference), operational supply voltage input (+12V & Gnd) and a CAN-bus as communication bus. The sensor measures every second the high voltage input and sends the value to the CAN-bus. As mentioned, the sensor is also powered with +12 VDC supply as operation supply. However the problem is that in the sensor I don´t have any galvanic isolation between the HV-measurement ground reference and low voltage supply ground reference. So the ground is same for both measurement and operational supply. In future there will be a 800V isolation between high voltage side and low voltage side but that kind of sensor is not available yet.
Because I can´t get the new version of the sensor soon, I have to make the isolation by myself. Could someone say if my idea is right and safe in the schematic that I´ve attached to this post? I´ve never been thinking this kind of design of isolations before.
The idea simply:
Instead of having the isolation in the circuit board, can I have it between the sensor and the vehicle. (The sensor is supplied by the low voltage system (+12V) in the vehicle and the CAN bus is also in the vehicle where the sensor is sending the data.)
Here is the schematic: View attachment Isolation_schematic.pdf
Thank you for all kind of help!
With kind regards,
E-Floyd
The idea simply:
With kind regards,
E-Floyd
