im reading with top3000 its saving hex file not jed file.My friend should write file (far from me) with ttl866 is asking jed file.Hi,
Your programmer (software) should be able to read the chip and write a .jed file to the HDD.
Klaus
at my programmer there os no way to save it as jed fileHi,
According manual it should be able to save as .jed file.
Just choose .jed as file format.
I recommend to read the manual, or use the "help".
Maybe you need to use "save as" or similar.
If you need more detailed help you should provide more detailed information.
Like: software name, software version, screenshots...
Klaus
The asterix is expected at the line end.Generated by Topwin Ver8
GAL16V8
*L00000 11000000000000000000000000000000
ALL GAL families have copy protection. Any designer will activate protection of his product.Hello all to Dear friends
Im trying to copy a gal16v8
i read file with top programmer but im not sure its copy protected or not.
also i need to help convert this file to jedec.
