Gain Margin and Phase margin in Matlab
Irfansw07
Member level 1
Member level 1
Can anybody plz give me this answer in Matlab :
If I have poles give as 100Hz, 1 MHz and 10 MHz and loop gain as 10^4 than what is Gain Margin and phase margin ?
And can plz tell how to calculate in Matlab ?
Thanks in advance
Use the function margin to aquire the phase and gain margin.
I have use it as Margin command and tf command also with num & den command but when I compare with text book result the answer is not same as here the both GM and PM is infinite ...
I was wondering if there is something to do with value being taken ?
Your problem is solved using zpk function rather tf one.
run..
[xx,xx,xx,xx]=margin(sys)
where..
sys=zpk([],[-1e2 -1e6 -1e7],1e4)
hence gm is so great and pm is inf.
I can see that the ωpc values remain same but with ur code its in rad/s but in book it is MHz.Also Gain margin is still different and phase margin is still invalid as compare to textbook result ...
I wonder can it be related to pi value insertion or r we have to assume this value as correct ?
Thanks in advance
