gain booster circuit in folded cascode opamp
ljy4468
Full Member level 4
South Korea
op amp booster
Hi everybody?
I've question about gain booster
I designed folded cascode opamp with gain booster
but I don' know exactly how much current flow in booster circuit
(I've designed main opamp and booster have the same current)
what's the relationship with current in booster?
Added after 2 minutes:
oh i've another question
gain booster circuit's unity gain frequency affect total block's(folded cascode with gain booster) unity gain frequency??
thanks for reading my text
op amp current booster
the booster must be faster than the main amp. (i.e. it's fu should be larger than fu of main amp)
cause u don't want it add an another pole in ur main amp.
gain booster
Hi.
Usually we consider a lower current for gain-booster. That's because we always like to have less power consumption. On the other hand, gain of the gain-booster is usually larger for smaller current values.
As you know, the gain-booster path introduces a zero (because we have two paths, a slow path and a fast path -> Razavi book) This zero can degrade the frequency response of the whole amplifier. So we usually use another capacitor to compensate this effect (place the comp. cap. on the output node of gain-booster -> K. Bult paper about gain boosting scheme).
Regards,
EZT
    ljy4468
op amp booster circuit
Hi EZT,
Do you K. Bult's paper which is published in 1991? If you can, please upload it here since as I know there are lots of people looking for it.
Regards
gain boosted folded cascoded opamp
hi
i found k. bult's paper in ieee explore
but there's nothing published in 1991.
However i think that is number 6 "fast settling CMOS ......."
what do you think about it?
And that paper says gain booster stage need not to be fast
which is opposite of BTREND's idea.
?????confused..
good day~
folded cascode gain boost
that paper is published in 1990,name is :A fast-settling cmos op amp for sc circuits with 90-db dc gain.and in this paper,the relationship between the gainboost amp and the amp are decribed in detials.which is a very classical paper i read.maybe you can find it by google.
operational amplifier current boost
Hi ljy4468.
Here is Klaas Bult paper about gain-boosting.
Regards,
EZT
booster opamp
Actually, the original paper is not from IEEE, but from a magazine named something like "Analog Signal Processing with VLSI" (I can not remember exactly), publisher is Kluwer Online in 1990.
op-amp signal booster
Hello Guys !
I asked this article concerning the gain boost to improve settling time .The publication name your are looking for is here :
I wrote it again
"Klaas Bult
The CMOS Gain-Boosting Technique"
1991 pp.119-135 Analog Integrared Circuits and Signal Processing
If someone can upload it ,thank
gain boost folded cascode
enjoy it.
klaas bult
little current in gain boost
folded cascode opamp gain boost
i think the booster consume less current
