fwrite in verilog....
lakshminarayanan
Newbie level 5
Newbie level 5
verilog fwrite
while using the fwrite in verilog....... as mentioned below....
$fwrite(file,"a=%d @=%d",a,addr);
if the value of a is negative i am getting the data in the file as.........for eg....-1 as 65535 but i need to print it as -1 in the file do any one know other format of writting the data so i colud write negative values as -1 in my file.....
fwrite verilog
Using %d should print -1, for example the following code works fine in VCS:
module fwrite();
  initial begin : b1
    integer file;
    file = $fopen ("a.txt", "w");
    $fwrite (file, "MIN_1 is %d PLUS_1 is %d ", -1, 1);
   $finish;
  end
endmodule
Output is:
  MIN_1 is          -1 PLUS_1 is           1
HTH
Ajeetha, CVC
www.noveldv.com[/code]
$fwrite verilog
Checkout this!
module test;
   integer file;
   reg signed [15:0] a, addr;
initial begin
   a = -1;
   addr = 100;
   file = $fopen("test");
end
endmodule // test
verilog $fwrite
i think if you have declared the variable 'a' as register data type, there is a possibility that it might not show the negative value since it might be unsigned by default. Plz check the fwrite statement with 'a' declared as an integer and see if the same problem occurs.
Also, please provide a feedback on this.
fwrite in verilog
The problem is fixed by the suggestion given by nand_gates........i am using the modelsim simulator in win xp ................
When I try the code above and simulate using Isim, the output has only one character, instead of "MIN_1 is -1 PLUS_1 is 1", the output is just M. Anyone could tell me how to solve it? Is it because I did the wrong simulation?
Thanks
What's the difference between $fwrite and $fdisplay?
just copy paste it from "verilog golden reference guide"
"The only difference between $display and $write, is that $display writes out a
newline character at the end of the text, whereas $write does not."
Thanks! Short and clear :)
