c70206150
this question is regarding the use of fuses in SoC or ASIC's
I have noticed that in newer designs, the number of fuse bits are quite high. As high as 20Kb for example
I can understand fuse values being used for ramp repair etc. but I see a lot of bits being used for IP configuration (e.g. to enable a feature or disable).
Normally, such configurations can be done using configuration and control registers.
So, the question is what is the reason why the new designs have such a large number of fuse bits?
