Winsu
Full Member level 3
Hi All,
I have come across a problem. I have tested a product against a surge test and it has failed.
It has this GDT between Live and neutral: CG2250L and it has also a this fuse before the GDT, fuse part number 37421000410.
The shape of the graph tested is like the image below indicates, where the peak voltage is 500V AC.
The product has failed the test and today and I have seen that the problem is that fuse is damaged.
I have replaced the fuse and the product is working perfectly fine. I think what has happened is that the GDT has shunted the current at a very low voltage ( 15V according to the datasheet, it is called the arc voltage) and the current has been increased a lot.
I think it is the problem, too much current or a lot of wattage in the fuse. The voltage across the fuse would be 500V-15V = 485V and if the PSU that supplies the pulse has a impedance of 2 ohms that would mean 242.5A. If this is correct that would mean a 117370W across the fuse for a very short period of time.
But in somehow it doesn't make sense, if GDT are able to bring down the voltage that much , that means that any fuse would be destroyed by that huge amount of energy. am I thinking right or am I missing something?
Any idea or help would be great, thanks
