I don't think there is a common formula.
Overtones are mainly caused by distortions:
Let's look at two cases:
1) audio amplifier, pure sine input, close to clipping:
The overtones are very low in amplitude, maybe -80dB
Now if you increase the input signal (fundamental) amplitude by 6dB..
Then the overtones will increase rapidly, maybe up to -24dB (referenced to the fundamental amplitude. not calculated) for the first overtone
2) audio amplifier, distorted sine input, not close to clipping:
The overtones do exist
Then the overtones will increase by close to 0dB (referenced to the fundamental amplitude)
In case 1 the distortion increases with amplitude, whereas in case 2 the distortion does not increase with amplitude, and there will be all other sytems inbetween.
Klaus
