Functions for equations in ADS
ahmad_abdulghany
San Jose, California, USA
Hello.
Does anyone has a book or pdf that includes a set of functions that are used in equations in ADS?
I want to make an equation to calculate the output voltage swing in transient analysis, what are steps to do that?
Also, I want if available a set of short cut keys that are used in ADS to simplify work on it .. i don't know any short cut keys except : shift+x to mirror about X axis , shift+y to mirror around Y axis and Ctrl+R to rotate .. :D .. I hope anyone know more ..
by the way I am using ADS2004A under Windows..
Thanks in advance,
Ahmad,
Re: Equations in ADS
Here are two relevant pdf files for writing
1. Measurement Expressions (expmeas.pdf)
2. Simulator Expressions (expsim.pdf)
For the output swing, you can just use two markers at opposite peaks and use the delta mode for the markers and see the dependent axis value...
You can also do it by using the max() and min() functions in ADS.More explanation in the expmeas.pdf
Regards
