Functional and physical isolation
Ben_Beckman
Newbie level 5
Newbie level 5
What is the difference between physical and functional isolation? How will they impact power?
Are you sure you mean "physical isolation" and this should be related to "ASIC design".
What do you mean with "power"? (Electrical power, processing power...)
I guess you ´ve read some article or document. Please give a link to it.
Klaus
Klaus
In the power domain crossing the isolation cells will be inserted in between power gated domain and always on domain. This is known as isolation. I came across this terminologies when I have discussion with people in PD team
you can think of isolation as making sure things are ok electrically. no current flows from/to the shut off block.
what is meant by functional isolation is not clear to me, I have not come across this term. it probably means that the blocks that are on should not expect any handshake from blocks that are off, or similar communication dependency.
