fully differential op-amp
firsttimedesigning
Full Member level 1
Full Member level 1
so fully differential op-amp has two outputs. but if i want to use it in an integrator, how should i connect? should the - output be connected to the ground? (please see the attached file)
Also, how do i measure the gain, phase and output swing of a fully diff amp? please some me some schematics....
the other terminal should have a similar branch like the input for differential operation
Your connection can work but it's not the best.
The better way is to use another RC connection like the attatched file.
i see...so the negative output should be connected just like the positive output...makes sense now...thx a lot
