Fully differential complementary output amplifier without CMFB
Junus2012
Advanced Member level 5
Italy
Hello
I have a basic question regarding complementary fully differential output like the one I have attached to this email, it is basically a modified version of the folded amplifier referred as recycled folded OTA, indeed my question is about the fully-differential scheme used in this circuit, as you can see , the circuit has two complementary output stage, in each, there is a mirror just like of the single-ended OTA, so I am not understanding if this circuit needs a common mode feedback circuit (CMFB) or not and why even need it.
I found the circuit from this link:
Also, I have made little research to see the original of this topology, and I found this US patent
I do appreciate your kind help
Thank you very much in advance
Best Regards
( Might be stating the obvious here, but the M14 source should connect to C1 rather than C2. Just a typo in the figure. )
My guess would be that - regardless - a CMFB would be nice to fix the levels at a desired point. Cannot see that it would automagically stabilize at vdd/2 assuming pure capacitive feedback. And with that said, is vdd/2 what you want for next stage, etc.
