full project using fuzzy logic control.
nemo_085
fuzzy controller projects
hi
i study fuzzy logic for my final project and i'm searching for an application to study , but i'm confused
i need suggestions
no suggestions ?
Reactions: peep
    peep
what field are you into? If you are with transportation, you can study fuzzy based traffic light. Controls sytems, refrigeration and airconditioning using FLS. Microwave Comm Design using FLS id you are in telecoms...
here is a very comprehensive site with much of projects for fuzzy logic.
"http://www.aptronix.com/fuzzynet/designnotes.htm"
you can find various projects there,
here are some contents:
1. Pattern Recognition using FIDE (machine vision and image analysis)
2. Multi-sensor data fusion using FIDE (smart air bags design)
3. Real-time control of inverted pendulum*
4. Fuzzy controller of intelligent washing machine*
5. Fuzzy auto-focusing for a microscope on space shuttles*
6. Servo motor force control*
7. Reactor control*
8. Automobile transmission control*
9. Disk drive spindle servos*
10. Fuzzy automated manufacturing*
11. Glass melting furnace control*
12. Fuzzy air conditioner control*
i know some other resources which must find them in a bunch of files and links , if you are intrested i can do it for you.
8) :D
What kind of application would you like to do? There are many application areas. Firstly, I would like to advise you that you should choose the project from your reference books. If you have any question, do not hesitate. I am also interested in Fuzzy Logic Control.
May I know do you need a fuzzy logic control example for reference, or some products with fuzzy control that can be installed on your equipments? If you need the products used in temperature control, I think I may provide you these products, such as some temperature controllers with auto-tuing PID control function? Should you need more info., please contact me by e-mail: wm@toky.com.cn. My name is River Wong.
Reactions: m.tork
    m.tork
if you're an undergraduate, maybe you can try your hands on something simple like line following robot or a washing machine system. all the best!
7. Reactor control*
9. Disk drive spindle servos*:oops:
8) :D
Hello , I just got attached to this forum recently, and I am doing undergraduate and having fuzzy logic course, but I have no idea what to do, and YOUR LINK IS NOT WORKING ,so can you please help me to give me some ideas on fuzzy logic project.Please I do need help ASAP.
My sugestion is to you research something about lead-acid battery charging control.
It is just required 3 parameter at input ( Temperature, Voltage, Current ).
