full digital sigma-delta modulator used in DAC!!!!
ls000rhb
Full Member level 3
Full Member level 3
can anyone give me some examples of Hdl code for full digital sigma-delta modulator used in DAC!!!! I want ot learn the way ot do some test for modulator's performance!!!
i need some very simple examples even though they maybe not appliable!!
Thanks !!!!
actually I think you need the modulator itself. it can used digital code to generate it . if you can understand the theory it will be single. it looks like a PWM generator. when it equals 1 just output high voltage, if this is 0. output 0. this is the simplest modulator.
then add the analog filter after that, it will help you generator the analog output
add a
See Book :
Added after 1 minutes:
Or Book :
