Full-Bridge SMPS on double sided PCB?
grizedale
Advanced Member level 3
Hello,
Is it recomended to do a full-bridge SMPS (330W; Vion = 90-265VAC) with charge-pump high-side gate drivers on a double -sided PCB?
eg using two NCP5181 gate driver IC's.......
https://www.onsemi.com/pub_link/Collateral/NCP5181-D.PDF
..its just that its four gate drive signals to route....and i wonder if this makes some go to 4 layer PCB?
it would depend upon on overall size of PCB, I think if you are able to route (with necessary shielding or physical separation) i think 2 layer be OK.
convert the pcb to single sided
double layer pcb's are horrible from servicing point of view,
i have not been able to remove a SMPS transformer from a double sided board as yet
I think if you can separate between High voltage and low voltage for noise and other and shielding , thats very good to design multi-layer board as atripathi said.
