grizedale
Advanced Member level 3
I think that offline Half-Bridge converters are a complete waste of time....am i right?
the FETs in a half-bridge only switch half of vin (due to the rail-splitting capacitors), so FET RMS current will be much higher with a half-bridge than a full bridge, and the fets will need to be more pricey with bigger heatsinks.
Also, the Half bridge needs highly expensive , pulse rated rail-splitting film capacitors.....these are more expensive than a mosfet....so the extra mosfets in a full bridge, would be payed for by the fact that the full bridge doesnt need the expensive film capacitors.
FULL BRIDGE COSTS:
4 FETs, Two NCP5181 Bootstrap fet drivers.
HALF-BRIDGE COSTS SO FAR
2 FETs, one NCP5181 Bootstrap fet driver, 2 Pulse rated film capacitors
...Already the half-bridge is looking awry...........but there's more woes for it........
the half bridge cannot utilise low-side resistive current sensing, because when the high side fet conducts...most of the power current would not go through the low-side current sense resistor.......so the half-bridge must use an expensive current sense transformer in order to be able to sense any primary overcurrents.
..the Full-Bridge can just use a cheap current sense resistor.
Also, in the event of overload, the half-bridges rail-splitting capacitors will end up with one discharged , and the other charged all the way up to the rail........which means that each rail-splitting capacitor must be rated for the full Vin of the DC Bus.....so thats two, expensive 400V rated pulse capacitors for the half bridge.
Also, the film capacitors for the half-bridge take up a large amount of space in the half bridge.
Is anyone seriously going to defend the half-bridge?
Even more woes for the half-bridge in that it cannot do peak current mode control without blowing itself up, or at the very least running in an unstable way...this is mitigated by adding a balancing winding, but thats more expense and complexity.
Also, since the half-bridge has more primary current flowing (due to the rail-splitting capacitors gaiving a low primary voltage when the fet switchs on)...it will require more filtering components, including capacitors, and will be harder to get through EMC.
So, Is anyone seriously going to defend the Half-Bridge vs the Full-Bridge?...Surely not?
FULL BRIDGE COSTS:
