Full Adder in LTspice using Diodes and single Transistor
Omkar Shinde
Newbie
Newbie level 3
I am trying to implement a Full Adder in LTspice using Diodes and single Transistor however i am unable to achieve the desired output. Please refer to the below screenshots. I am unable to add relevant asc file for refernce as the extension isnt supported here
The below article is used as reference.
https://www.instructables.com/One-T...cally a full adder is,full adder can reach 18.
you are using three input voltage sources (A, B & C) with ahigh value of 1 V.
Where are the nodes V(n001), V(n002) and V(n006) in your circuitry?
BR
--- Updated ---
How should your "desired "output look like? Your used LED has a quite high forward voltage. Thus you can not expect the same results as described in the provided link.
BR
--- Updated ---
i have attached the desired output image
BR
--- Updated ---
the nodes V(n001), V(n002) and V(n006) are my input carry nodes. They are located just before the three 10k resistors. N of diode is almost double the V forward which is true in most LEDs i checked online
Referring to a new article i have created this new full adder using diodes and resistors now
how do i get output in this?
  • full_add.pdf
It's wrong to use 1 V input sources in post #1. Review the original article, they are using 5V input. I won't name the circuit an adder unless you have level comparators that convert the analog output voltage to defined logic levels. Is so far the full adder circuit is a kind of bluff package.
Post #5 circuit takes a different approach by using non-inverted together with inverted input signals. The adder core uses only diode logic, but it can't work without external inverters.
A fully featured adder can be cascaded without additional inverters or buffers. In so far neither of the presented circuits is a complete adder.
