ehsan_iut
Junior Member level 1
I'm involved in designing a rather simple state machine. I was looking at the "language template" of the FSM in Xilinx ISE. In that templates, the output is assigned to internal signal at each state. Then these internal signals are assigned to the output ports in a clocked process (The same process in which the state transition occurs). Is it necessary to latch the outputs of the FSMs? Does anybody know the reason or have any experiences? What do u usually do?
Thanks alot!
Thanks alot!
