jango123
Newbie level 5
hello , i try to make a fsm with a reset and one bit input a and output y to detect the sequence "1101"
i code it with vhdl and simulite it but it dont work
please help me thank you
library ieee;
use ieee.std_logic_1164.all;
entity machine is
port(
rst,clk,a : in std_logic;
y : out std_logic);
end machine;
architecture arc of machine is
type m_state is (s1,s2,s3,s4,s5,s6,s7,s8);
signal state : m_state :=s1;
begin
process(clk,rst) is
begin
if (rst='0') then
state <=s1;
elsif(rising_edge(clk)) then
case state is
when s1 =>
if a = '1'then
state <=s2;
else
state <=s1;
end if;
when s2 =>
if a = '0'then
state <=s1;
else
state <=s3;
end if;
when s3 =>
if a = '0'then
state <=s4;
else
state <=s1;
end if;
when s4 =>
if a = '0'then
state <=s1;
else
state <=s5;
end if;
when s5 =>
state <=s1;
when s6 =>
state <=s1;
when s7 =>
state <=s1;
when s8 =>
state <=s1;
end case;
end if;
end process;
process(state)
begin
case state is
when s1 | s2 | s3 | s4 | s6 | s7 | s8 => y<='0';
when s5 => y<='0';
end case;
end process;
end arc;
