edinburghtech
Junior Member level 2
Hello
I would like to design a wired communication system between 2 buildings say 150 meters apart.
My idea is to design a transciever which can be used on both ends of the wire channel
Transciever will employ either FSK or PSK for data transmission/reception
I would like to know how to estimate minimum signal power required to transmit data successfully across this distance using a twisted copper pair wire. Also how can i estimate minimum frequency and voltage levels for successful implementation of the system.
Please advise
Regards
Edinburghtech
Please advise
Regards
Edinburghtech
