hkBattousai
fsk demodulator ic
Q1) 10K + 10K pot combination is the external timing resistor required by the IC itself which is connected at the 8th pin. Why do we connect the 0.001uF capacitor between 7th and 8th pins of the IC? What is the importance of this capacitor, why is it needed, what would happen if we don't connect it?
Q2) Why do we use a, as high as, 3rd order low-pass filter at the 7th pin output? Are there so much ripples there? Or do we have another reason? Will a first order LPF be adequate in a theorical circuit if the frequency difference between the two input frequencies is perfectly 'digital' (e.g., frequency difference is either 0Hz or 100kHz all the time)?
