[SOLVED] FSK demodulation poblem.
hamidkavianathar
Member level 5
Member level 5
I want to simulate the FSK demodulator. these are my parameters:
F1 = 16.5 kHz - 64 Hz, F2 = 16.5 kHz + 64 Hz.
as the difference between F1 and F2 is very small, I can't extract my data correctly. Can someone guide me?
thanks.
How are you extracting the data?
thanks for the comment. this is my algorithm:
I have simulated it in MATLAB/simulink environment.
What's the timing of the accumulator control signals?
Summing quadrature magnitudes doesn't give the absolute magnitude, need to calculate squared sum.
thanks for your attention and your help.
I think calculated the sum in this block diagram:
and I have illustrated my signals in this image:
in the above image F1 = 16564Hz , F2 = 1643 Hz. the difference between F1 and F2 is very high, but I couldn't retrieve my data.
Squaring the product before accumulator can't be right.
thank you. You helped me very much. I have no idea how I can thank you.:clap:
you're right. I modified it and it according what you said and now it works very well.
I want to ask you another question, do you know how i can make it robuster? I have not consider the distortions.
