From RS-485 to RS-232+isis disgn
xxtigerxx
Advanced Member level 1
Greece
I want to send and receive data from my PC from a network RS-485
Do you have any cicruit?
THX
Re: From RS-485 to RS-232
To convert RS485 to digital use MAX485, and digital to RS232 use MAX232.
Reactions: XoDoK
    XoDoK
see your schematics in this link :
more info :
If you make some assumptions and use some tricks the RS-232 to RS-485 half-duplex (2-wire) converter can be quite simple (see attached circuit) ..
Assumption1: Most of Laptop and PC COMs will happily accept 0-5V level on Rx pin ..
Trick1: Steal power from serial port ..
The resultant circuit is self-powered, will work with any baud rate >115kbs and doesn't need direction control (automatically switches from transmission to reception) ..
There are, as usual, small drawbacks .. but who cares about them if circuit works OK ..
Have fun ..
Regards,
IanP
This link 's very good. U can refer:
Dear IanP
can i use this converter with s7-200 PLC
Best Regards
MedTronic
