From assemblet to C in MSP430
lolek2
Newbie level 2
Newbie level 2
Hi
I would like to write some constant value to RAM. In assembler, MOV(.B) is the instruction used to do that. Do you know how to do it in C?
Then, I want to add to this constant value some other constant and write it in memory address of the first constant.
Regard,
lolek
heve you ever tried
asm (MOV(.B))
or asm { MOV(.B) }
? try it!!
you will use this assembler instruction in your C program. Don`t worry, is quite commom to use this is microcontroler programming...some cases is faster to do this...
regards
Breno
    lolek2
This is my first expierience in programming. I do not know if I am building instruction in the proper way ( I want to write for instance 1 to 0200h):
asm { MOV1,0200h } ; or
asm (MOV 1,0200h) ;
In each case there is the error:
"expected an asm string".
regards,
lolek
