from 0.1-0.2V to 1-4V scaling
jonnybgood
Full Member level 4
Full Member level 4
What configuration do you recommend for scaling an voltage range from 0.1-0.2V to 1-4V using a single supply op amp.
I derived the straight line equation : Vout = 30Vin - 2, which will give to required output.
I tried a lot of techniques with summer circuits/ level shifters but could not solve the problem.
appreciate any help. thanks
Your possible range of input covers 50% of maximum, to 100% of maximum.
Your desired range of output covers 25% of maximum, to 100% of maximum.
The most direct solution is to subtract a fraction of a volt from your input, so that the op amp receives a 25% to 100% possible range.
Then set gain to create your desired output.
