soroosh.strife
Newbie level 2
Hi
I have got a mini2440 with 7" LCD and I successfully installed linux on it. Now I want to use it's peripherals so I need to know which pin on the microprocessor is connected to which pin on the board. I read the mini2440 manual but it seems my board is a little different from the one described in the manual. For example in the manual says CON4 port has 34 pins but my CON4 port has only 20 pins. So I guess I should find the right manual or at least schematics for my board. So if you know of any other boards please let me know.
Below I posted some images of my board I hope they help find what I need. Also if you need to know anything else please tell me.
Thank you
Thank you
