harvie
Full Member level 1
Hello,
i am building the diy silent air compressor from old fridge and and fire extinguisher. It has some sort of starting relay and no visible capacitor (i suppose start capacitor is sealed inside compressor. right?).
What i understood is that when it's connected to power the relay (probably ptc) is closed (=cold ptc). And current flows to the start winding. As times go the ptc warms up and disconnects start winding, leaving only run winding to do all the job.
But i have pressure switch which disconnects compressor at 8 bar and reconnects it when it drops to 6 bar. But when i use the compressed air too quickly it thereforem may happen that ptc will not yet be ready and cold for next start, which means that power will be applied to run winding without energizing the start winding. Compressor does not start in such case.
What should i expect when this happens? I am afraid that it can damage run winding because current flows thru it without motor really rotating which may result in bad motor cooling and burning up the run winding. I've heard that some PTCs have integrated thermal protection of run winding, but i am not sure if it's ok to trigger it too often (during normal everyday use).
I've been thinking about replacing ptc with electronic timer relay or something that would engage start winding for few seconds every time power is applied. But i don't know if it's good idea and i also would rather keep things simple.
Cycling fridge compressor without unloader valve?
Next thing i am afraid of is what will happen if compressor will start with air tank pressurized to 6 or 10bars? I am not going to use unloader valve to simplify the design. First experiments shown that it was starting at around 7 bars few times, but i didn't done any repeated tests or tests at higher pressures. What pressures are in fridge when compressors start? is something around 8 bars ok? i've heart these beasts can go up to over 100 bars, so i guess 10 bars should not be considered "load". but i don't know.
