djalli
Advanced Member level 3
frequency multipliers
I want to multiply the frequency of a signal. If the signal I will generate is at range 0.5Hz to 5Hz how I would multiply 10, 100 times this frequency. Imagine the signal I am is amplifying easily in amplitude with OP-97 IC which uses very little current resulting of a low power consumed which is my biggest concern.
thank you all.
thank you all.
