natdon11
Newbie
Hi plz bare with me as i am a bit of a novice when it comes to verilog.
I have been tasked with producing a frequency divider implemented in verilog from a counter module that I have made earlier. The idea being the counter counts to a set value then resets, when that happens it toggles an output which is the divided signal.
My counter module: (this counts to its max number on the 24 bits then resets.)
as you can the output of the counter is a register.
The issue i am having is when trying to instantiate this module inside my frequency divider module:
I need to be able to access the output from the counter module "out" however I realised that I couldn't connect a register straight to the output of the previous module. So a tried to connect it to a wire then update new register with the value on that wire. However this has caused me all sorts of errors. So my question is how to I set up my clock divider module, So that I can access the output register of binary counter and use it to toggle an output when it reaches a certain value.
The current error I am getting is:
Error (10200): Verilog HDL Conditional Statement error at ClockDivider.v(22): cannot match operand(s) in the condition to the corresponding edges in the enclosing event control of the always construct.
marked in the code.
Thanks in advamce for any help
module nBitBinaryCounter(
input clk,
input rst,
output reg [23:0] out
always @ (posedge clk or negedge rst)
begin
if (rst == 1'b0)
out <= 1'b0;
else if (out == 23'd16777216)
out <= 1'b0;
else
out <= out + 1'd1;
end
endmodule
module ClockDivider(
input clk,
output reg clk_out,
output reg rst
wire [23:0] count;
reg [23:0] count_reg;
nBitBinaryCounter count1(
clk,
rst,
count
always @(posedge clk or negedge rst)
begin
count_reg = count;
if(count_reg == 24'd5000000) //line 22 error
begin
clk_out <= !clk_out;
end
else if (rst == 1'b0)
begin
clk_out <= 1'b0;
end
end
endmodule
marked in the code.
